How to resolve Colorbond fence installation issues?
jfordham
Hi
i had a fencing company install a new colourbond fence to an investment property and they are adamant they have done it correctly…
as per pictures they have installed some of the fence posts ontop and into existing timber posts used for an existing retaining wall.  I’m not a fencer but I assume using the timber posts is not structurally sound and all the posts need to be 600 or 800mm in ground and concreted?
I will speak to them again but assume this all needs to be ripped out, and maybe reinstalled in front of the wall and directly into the ground and concreted?
Re: colourbond fence installation issues
Hi @jfordham
You can hang gates from either side the gate s hinges need to sit on a post ideally that's into the ground or attached at the top to bottom onto the wall.
A gate needs two posts hinge side then the latch side.
If you swap sides the gate swings from just make sure the gate latch is reversable, or you will need a new one.
If you want and in swinging gate or out swinging gate this is easy to do by adjusting hinge positions just the latches need to match that operation.
My gate has a latch pin for in swinging, but this won't allow the gate to open outwards, and it will hit the gate frame and the security of the gate is good as the latch is inside of the gate.
If the same latch used on the outside, you could lock people in but anyone can open gate from the street.  So a new latch that is lockable on the outside is needed.
I hope i didn't over complicate all that
Hi @jfordham
At  this time the wall is a better   hinge mounting location done this way below
Ideally you would mount a 50 x 50 mm post to the wall sitting on the concrete lol is ok The key difference here is the post will be held in place with at least 3 to 4 mounting places the full height of the gate a per color bond guide  book.
The gate in the photo is only held in at the bottom to the wall 1/4  height up a strong wind can blow it over as there is only the fence rails and panels but no upper post support for the hinges
