Possible Tap Adaptor?
kaacu1
Hi folk, is there an adaptor I can change my garden tap outlet
garden-tapgarden-tap
to standard
standard-tapstandard-tap
so I can fit the tap timer?
timertimer
Jewelleryrescue
Kind of a Big Deal
Re: Possible Tap Adaptor?
Hi @kaacu1
I have never seen a tap adaptor go from a clip on fitting to a 25mm timer screw
thread.
I think the best solution is a New tap  I think I am seeing a 20mm tap connection in the photo please check this is correct/
So the tap is its either 25mm connection or a 20mm just buy the right size tap to screw into your wall fitting after that you can use any type of water connection outlet or timer.
Hi @kaacu1,
I agree with @Jewelleryrescue that installing a new tap with the required threaded fitting would be the easiest and most reliable option. This way, you can ensure compatibility with the tap timer without the hassle of searching for an unusual adaptor. Just check the current size of your tap connection on the wall, and then purchase the corresponding tap that will fit your fitting. This will make it easier to connect your desired water outlet or timer.
