this is my Dish it’s 2m in diameter. This picture is when I first got it and set it up, but since I have let it go and I want to re-establish it with Plants. I bought some water plants and also some floaters which are black rubber rings that hold the pot up so I thought I would try that this time because I found it with regular pots. The water got really dirty. So my question is given that it’s mostly the roots that will be dangling in the water what soil mixture should I use. There doesn’t seem to be a lot of advice about these floater devices and I wasn’t sure whether I should be using the same soil as normal or something different. Thanks so much
Hi @gillymrd,
I can't say I'm 100% positive about what the best course of attack would be in this situation, but I suspect the issue of cloudiness is due to the silt in your soil. There are aquatic soil mixes, but I'm not aware of a product you could purchase for this purpose.
I would use regular potting mix, but I would soak it until the water coming out of it runs clean before dropping the pots in your pond garden. This should clear away the lighter silt before it is placed in your pond.
Allow me to tag @Noelle, @mich1972 and @Jewelleryrescue to see what they think.
Thank you for response.
I wasn’t sure about your response as I didn’t mention cloudiness or silt however I appreciate your interest.
If you think the members you tagged might help I’ll be very grateful.
cheers
Gillian
Hi @gillymrd,
I may have misunderstood what you meant when you said, "the water got really dirty".
Was it not dirty because of the potting mix? Was it more of an algal problem?
I had assumed that the moving water was picking up the light particles in the soil, which is silt.
Thanks again, the dirty water comment was how it was previously that’s why I have decided to try the floaters (which you sell near the aquatic plants )so that the plants roots basically sit in the water but not the whole pot. .
so I’m looking for suggestions for potting mix for this new system of putting pots in floaters.
thank you.
Hello @gillymrd
One medium you can try to use is the Brunnings 2.5L Hydro Clay Pebbles. They are baked clay balls made by baking and tumbling natural clay at high temperatures. As a result, they are super lightweight and porous with high air content. Hydro Clay Pebbles have a neutral pH value, are fungus free and will not rot. They also absorb moisture when soaked in water. They are often used in hydroponics and aquaponics where a soil free medium is required. This should keep your water clean and free of soil and dirt.
I also suggest at having a look at the Osmocote 250g Scotts Water Gardens And Aquatic Plants Controlled Release Fertiliser to help keep your plants fertilised.
Here is a handy guide to help with your project: How to grow aquatic plants.
Hi @gillymrd
Just to start off, think about plants only need nutrients not soil. !!! As a casing point hydroponics need no soil consider your pond like a hyroponic pond.
We just mentally assume plants grow best in soils etc because that's how a zillion plants growing real soil getting nutrients out of the soil.
So the real purpose of soil in water is to hold the plants and roots in place while letting the plant root access the water and added nutrients. As long as we feed them with a liquid fertilizer or equivalent with minerals for ponds. Basically, that's what we do for land bases plants anyhow.
Your Question is soil types. Don't use regular potting mix as it will keep mudding the pond in your situation.
@JacobZ is 1000% correct in suggesting aqua Soil mixes usually sold by pond suppliers. Typically, this soil has little to no clay and fine silty partials to cloud /dirty the water.
Your pond ideal Setup is
1 Aqua soil in pots Many to choose from look in your local area.
2 Osmocote Aquatic plant food This is month slow release fertilizer for water and has no nutrients water build up for algae blooms
3 if algae blooms occur green water in vert in a one pond filter pump and uv light for good clean water does not stagnate. As your pond is full sun too.
4 optional Small pretty fish that don't mind the out doors as they eat mosquito Larve etc.
Nice feature pond enjoy.
