Planting over stormwater drain
Hi There,
I have a stromwater drain and pits at the back fence of the house (pic attached).
What plants/shrubs, I can and cannot plant. Also, I am looking for ideas to hide those pits.
Thank you
Bronel
- Labels:
Gardening
Landscaping
Plumbing
Re: Planting over Stormwater Drain
Welcome to the Workshop community @bronelchristian. Many thanks for you question, I'd be happy to give you some advice.
When planting in an area near to stormwater pipes it is always best to select trees or shrubs that are small and slow-growing. The water pipe should be in good condition as older pipes made of terracotta are particularly vulnerable to root penetration. It is not recommended to plant closer than 10m from a stormwater pipe, any closer and you should also install Whites 600mm x 5m Recycled Garden Root Barrier. This needs to be installed from the surface and down to at least 60cm deep in between the plant and the pipework.
Some trees that you should not consider- camphor laurel, fig trees, poplars, rubber plants, willows, Australian white cedar, casuarinas, coral trees, elms, large gum trees, liquidambar, jacaranda, illawarra flame trees, pine trees and pepper trees.
If you would like to take some images of the stormwater pits, then I'm sure our helpful members will be able to come up with some great suggestions on how to hide them.
If you need further advice or have other questions, please let me know.
Thanks Mitchell. That's very useful information.
To clarify, it is advisable not to plant trees closer to stormwater pipe. However what about shurbs and veggie plants? Do you think it is still advisable to follow the 10m rule? Also, I have a backyard of 15m, so if I write off 10m that means I will be planting closer to the slab which might be not advisable as well.
I am not planning to plant any trees (if I do it might be dwarf fruit trees), what shurbs and veggies would you recommend to plant over the stromwater pipe?
This is the new development so I hope the pipes used are PVC and not terracotta.
I have attached a picture of the strom water drainage pits, I was thinking to put a retaining wall at the back and create a veggie garden. Do you think this will be feasible or I will be looking at issues in 5years time.
Thank you
Bronel
Hi @bronelchristian,
If you take the leaves and branches on a plant and flip them upside down, that is at least the equivalent amount of roots they will have. So your veggies should all be fine and when picking shrubs just make sure you keep to dwarf varieties. You can, of course, come closer than 10m with shrubs, but I would not plant many large trees within that distance.
For the veggies, you might like to consider a raised garden bed as areas with drainage pits often get water-logged. Small shrubs can also be grown in large container pots and that will allow you to move them around as you fill the area.
Hi, i have same situation, but can i plant citrus tree like mandarin, lemon and lime trees near the stormwater drain?
Welcome to the Bunnings Workshop community @ninsreyes. It's terrific to have you join us, and many thanks for your question about planting citrus trees near stormwater drains.
Here's some information provided by Sydney Water about wastewater blockages. They advise trying not to plant any trees within six meters of pipes. Those citrus trees don't fall within the aggressively water-seeking plants list. However, knowingly planting any tree near a source of water is at your own risk.
Do you know if the pipes are the old terracotta or the newer PVC variety? If they are terracotta, I wouldn't advise planting near them.
Dwarf varieties of citrus flourish and fruit very well in large containers. I use half wine barrels as they provide adequate room to grow in and look fantastic as well.
Hi Mitch,
Please refer to the image attached. I'm in the same boat. Can I lift up the pit's height and cover it with something removable and put flower pot in top of the slab? Myland is slightly slopped towards the rear where those pits are. And we're thinking of filling the backyard to make it flat and plany some veggies, flowers. But we have no clue what to do with these drainage pits. What would be the best option you think?
1. Leave the pits alone outside and puah the boundary wall inside.
2. Extend the pit level high as ground leve and use some sort of removable cover and plant veggies on top. Thank you in an advance.
Regards
Binit
Welcome to the Bunnings Workshop community @binitsanu. It's wonderful to have you join us, and many thanks for your question about drainage pits.
Given that you are planning on changing the height of your yard, it might be best to enquire with a qualified drainage expert on what options are available to you. You could certainly raise the pits to suit the new elevation, but you need to consider the fall on the attached pipes. It would be ideal if you could leave the pits where they are and use a pit riser to extend their tops and finish flush with the new soil.
Were you intending on installing a retaining wall at the rear of the property to prevent the new soil from coming in contact with the fence? If so, it appears as if it would need to be placed directly over the pits. If this is the case, you could consider putting the wall in front of them, and I'd recommend consulting a drainage and landscaping professional before proceeding.
Let me mention @Adam_W to see if he has any thoughts.
Thank you Mitch for your reply. I'll definitely consult with one of the drainage experts.
Re: Planting over stormwater drain
Hello, I’d be interested to know the outcome of the landscaping, did you manage to hide the pit? Would love to see what you did with it
thanks
Subject | Author | Posted | |
April | |||
November 2023 | |||
June 2023 | |||
March 2022 | |||
October 2023 |
