How to treat yellowing Gardenia leaves?
SarahO
Hi all,
A few of my gardenias (2 years old) are yellowing. They are in full afternoon sun however we are in a frost prone area of Melbourne. I'm wondering if this could be from the sun or frost damage or too much water?
Photo attached.
Thank you 🌿
Re: Yellowing Gardenia Leaves
Hi @SarahO,
I'd suggest you have a quick read through How to diagnose a sick plant from @Noelle our resident horticultural guru, this will likely shed some light.
Start by inspecting the plant for fungus or insects. I can't see evidence of this from the photo, but either of these things can cause yellowing and browning of leaves. It's unlikely, but it's worth confirming there are no issues on that front.
The more likely cause of the yellowing is over or underwatering or a nutrient deficiency of some kind.
Pull back the mulch and inspect the soil around the base of the tree. Overwatering can certainly cause this issue, so if you find the soil is quite damp, I'd suggest reducing the amount of water you are giving it and keeping the mulch back from the base of the tree.
Nutrient deficiency is also a potential cause which can be addressed with an application of Scotts Osmocote Roses, Gardenias, Azaleas And Camellias Controlled Release Fertiliser. Ensure you follow the manufacturer's instructions about application rates.
Gardenias like slightly acidic soil, so checking the soil PH with a Manutec Garden Care Products Soil PH Test Kit can also help direct your approach. If you find the soil is not in the correct range between 5.0 - 6.5 we'll have to either increase or reduce the PH. You can reduce soil PH by adding acid in the form of Sulphur Fine Granules
and increase it by adding an alkaline in the form of Natural Dolomite Lime.
You might also like to have a read through Growing Gardenias: How To Grow Gardenias for some additional guidance.
Allow me to tag @mich1972 to see if she has any other advice to offer.
Noelle
Kind of a Big Deal
Hi @SarahO
My guess would be too much water. While gardenias prefer a friable loamy soil that retains moisture after watering or rainfall, they do not tolerate 'wet feet'. The soil should drain well. The brown leaf tips are the giveaway indicator the roots are not happy.
Some protection from extreme afternoon sun may be beneficial.
SarahO
Re: How to treat yellowing Gardenia leaves?
Hi @JacobZ and @Noelle ,
Thank you so much for your detailed advice and suggestions. It seems the gardenias are over watered. They will be receiving water from the garden irrigation as well as some of the run off from the grass irrigation. The soil is very dense and clay like, and the drainage is poor due to this.
I will move the mulch back and see if that helps the plant.
Should I remove the yellowing leaves or wait until late autumn for a prune?
Thanks again,
Sarah
Noelle
Kind of a Big Deal
Hi again @SarahO
The yellowing leaves will drop off of their own accord - no need to cut them off.  I wouldn't recommend pruning them coming into summer as any new growth produced as a result may be susceptible to extreme heat and burning. Wait till the weather's a little milder in autumn.
