How to treat Fuji Apple tree with spots on fruit and leaves?
This Big Red Fuji tree seems to have several different issues.
I’d love some help to identify and treat them.
Thanks in advance.
Pics below.
Re: How to treat Fuji Apple tree with spots on fruit and leaves?
Hi @John57
Sorry to be the bearer of bad news, but your apple tree is affected by Apple Scab, a fungal disease that is quite prevalent in Australia.
According to the Victorian Department of Agriculture: "The disease can reduce the quality and size of fruit. It can also cause premature fruit drop, defoliation and poor development of fruit buds in the next season. Under favourable conditions and without control measures, apple scab can cause total crop failure.
"The apple scab fungus usually survives over winter under the trees, in the dead, infected leaves from the previous season. Occasionally, twig infections, infected bud scales or infected leaves that remain on the tree over winter can provide an overwintering source of spores. Leaves infected with the apple scab fungus usually fall from trees in autumn or early winter.
"The fungus continues to live within the leaves during winter, forming small, flask-shaped bodies, in which spores (ascospores) develop. These ascospores mature in spring and are forcibly ejected during spring rains.
The time when ascospores mature coincides with the period of rapid development of buds, flowers and leaves. Ascospore discharge occurs over a period of about 8 to 12 weeks. Mature ascospores are present by early September, and the greatest numbers of ascospores are released from late September to mid-November. This is the high-risk period for infection with apple scab."
The main methods of control are:
- using protectant and post-infection sprays in spring
- sanitation practices to reduce scab carryover.
Protectant sprays of suitable fungicides are needed at green tip, pink bud and at regular intervals afterwards. This is to make sure that rapidly developing leaves and fruits are covered with a fungicide residue that will prevent spores from germinating.
Most fungicides won't cure an established apple scab infection after the lesion becomes visible to the naked eye, but some will suppress the formation and germination of spores on the established lesion as long as spray residue remains.
Thanks @Noelle. Sad news indeed. Can the fruit be eaten? Should it be discarded, now? Picked early and thrown away? The tree trimmed of leaves, the ground cleared which is tough because its mulch. Then sprayed?
Hi @John57
The fruits can be eaten as the disease does not affect taste nor does it pose a threat to you. However, you may find there are spots on the apples under the scabs which you should cut out after peeling.
Don't trim the tree of leaves - wait for the natural fall during autumn but do try to gather them up and dispose of them in the household rubbish - don't add them to the compost bin or allow them to remain on the soil as mulch.
Spray the bare branches immediately after leaf fall making sure to thoroughly wet stems so the growth and flower buds receive a good dose - they may be small now but they are capable of harboring fungal spores over winter. Spray again at 'bud swell' - when you notice the flower and leaf buds starting to become bigger at the end of winter into early spring.
Thanks @Noelle
The tree needs a trim, and we plan a winter prune.
I guess we can prune after the leaves drop, and before we spray.
That would be the best way to go!
