How to save dying weeping blossom tree?
Cher54
weeping blossom tree bought 3/4yrs ago replanted in the  winter looking sad come spring sprayed leaves & limbs with seasol washed of 3 days later when leaves/ limbs started to die, now has 2 spots of sap on upper trunk, new leaves dying of b4 they shoot, tiny black spots & leaves are being eaten looks like a white wax peeling of a couple of smaller stems. I think originally I over fertilised it now several problems hole you can help I really don't want to lose it
Cher54
Re: dying tree
no water around roots spil is moist full tree & leaves being eaten & white wax on some limbs
Re: dying tree
Hi  @Cher54
Great work on trying to save your tree hope you/ we succeed
Where you dug the soil out and it is dry I might dig a little deeper past the roots and fill it with potting mix with water crystals. So the potting mix will get wet and will drain but holding good usable moisture levels without rot. The plant will send roots in as it needs.
I like using an old soft drink bottle here 1.25L with holes punched in it with the cap showing above ground for a quick deep water of the roots pop the cap off and add water. But I pre dug deeper and mixed in pearlite into the soil to for good drainage under the plant. I tend to over think some situations for younger plants,
Just thinking out allowed
Re: dying tree
Great will try this as well as  a lite spray of Yates Anti Rot & hope for the best
Thanks for all the advice
Cheryl
Re: dying tree
Hi @Cher54,
Overall, your plant looks quite healthy. If you haven't fertilised for some time, it would be worth doing so. Also, you might like to add some compost around the plant for an additional boost.
When fertilised well, the amount of new growth should overcome the occasional leave eaten by an insect.
Cher54
Re: dying tree
Put compost around it approx 4 weeks ago. Slow release fertiliser the best?
Re: dying tree
Hi @Cher54,
I do not see much compost in your image, and the soil looks rather unnourished. How much compost did you apply? I'd suggest a bag and a half of 25L compost mixed into the surface layer of soil or as deep as you can without disturbing the roots.
Slow-release fertiliser would be the way to go.
Cher54
Re: dying tree
Going to compost & add slow release fertiliser this arvo when it cools down
Thanks for all the advice 🤞
Cher54
Re: dying tree
Hi Mitchell have followed all you advice the tree is looking much better already. Thank you for all your help
Re: dying tree
That's great to hear @Cher54. Many thanks for your update.
Cher54
Re: dying tree
morning Mitchell, well my cherry blossom tree was going ok, now it starting to die again, I'm at ends as to what to do now besides pull it out & replace it it was doing so well even had a little flower coming up
