Hi there, I’ve just today bought one of these and while I’m happy enough with it, I believe it could do with some reinforcement at the edges holding up the aluminium sheets. They are plastic and only held in place with a top cap, no similar clamp or other item at the bottom edges. I was thinking some sort of sealant or even just high strength superglue to adhere the sheets to the edges and caps. Keen to hear suggestions or better options if anybody can help me out. Thanks very much in advance.
Hi @heychikadee,
Provided the product has been assembled correctly, there is no need to add adhesive to the corners. They've been tested by the supplier and they haven't identified any issues with them coming apart. However, if you wished to to so, I'd recommend you use Sikaflex 11FC, which should provide additional strength to the corners.
Great thanks for that!
Yes I’m sure it’s been tested and all, however I just want to be extra sure because it’s partly being used to block a gap under my fence so my cats can’t escape.
Hi @heychikadee
I hear you re cats escaping they need to stay in your yard and by safer they will live a longer happier life on average that way.
To add to @MitchellMc suggestion outdoor liquid nails will hold those sheets up.
And if you have color bond fence with the 50mm gap underneath I used orange sized rocks jambed under the color bond so they cant squeeze through generally they dont dig like dogs as a rule.
