How to prepare base for paver brick garden edging?
Ona-Budget
Whats the quickest and cheapest way to prepare a level base to set these recycled brick pavers in mortar? I want to use white mortar and white wash :smile: thanks!
Re: easiest way to prepare base for paver brick garden edging
Hi @Ona-Budget,
Thank you for your question.
The quickest and cheapest way to create a base for your brick paver garden edge is to excavate a trench 100mm deep and around 100mm wider than your pavers, add road base to the trench and compact it with a tamper. Check for level as you compact with a spirit level.
Once your base is prepared, you can lay your brick pavers, using the wet mortar to make fine adjustments to the level.
