How to paint or decorate Cottapot?
saloni
Which material can I use to paint or decorate a cottapot it is made up of Ecospecified 100% recyclable material
Re: How to decorate Cottapot
Welcome to the Bunnings Workshop community @saloni. It's terrific to have you join us, and many thanks for your question about painting a pot.
I can't find much information on these pots, including what they are made of, so I suspect the best source of information on how to paint them would be from their supplier. I presume they are some type of plastic, and if that is the case, it would be best to prime them with a plastic primer before using a spray paint. There are many different types of plastic, some able to be painted better than others, so I recommend doing a test section to ensure the prime and paint adequately stick to the surface. Spray an inconspicuous section and wait for it to dry. You can then scratch the area with your fingernail to see if it comes off.
