How to join slotted ag pipe to pvc pipe for wicking bed?
Hi, is there an easy way to join 65 mm slotted ag-pipe to 40 mm pvc pipe?
Re: Wicking bed inquiry
Hi @Fungus
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your agi-pipe.
I suggest using a Vinidex 65mm Draincoil Coupling in conjunction with a Holman 65 x 40mm PVC DWV Taper Level Invert and then linking your 40mm PVC pipe to the reducer. Please note that you'll need to silicone the end of the PVC reducer to the Vinidex coupler in order to prevent it from slipping out. If the PVC reducer is slightly too big, I suggest using a heat gun to loosen up the Vinidex coupler.
Subject | Author | Posted | |
July 2021 | |||
September | |||
November 2023 | |||
April 2024 | |||
July 2021 |
