I've recently had some retaining walls installed and now am hoping to install some "temporary" fencing along the top of the LOWER level (see below) primarily to deter the family from getting to close. Options I've seen include basic picket fencing (metal or wooden https://www.bunnings.com.au/rapidfence-2200-x-41-x-1200mm-black-blade-picket-fence-panel_p0438319), wire fencing and posts, or even glass pool-side-type fencing. I can't dig behind the wall: we have SUPER hard rock and digging and concreting posts is not an option, plus there isn't much space anymore). Plus I plan on removing the fence in a few years once family has grown up enough to stay away from the edges.
Can I simply bolt posts into the top of the wall? Would it be better to bolt to the front? There's only 50-100mm space on the rear of the wall to bolt to the back.
I'd love some ideas, or tips, or further advice.
Hi @bengroll,
You can create @EricL's design using 90 x 45mm Treated Pine and attach the frame pieces together with Zenith 8 - 10 x 100mm Treated Pine Countersunk Head Screws. When attaching the frame to the top of the sleepers, I recommend using larger fixings like these landscape screws.
Thanks @MitchellMc .
@EricL's design is still my preferred option and your supply and equipment details are great. My (hopefully) final question is what to fill the spacing between the posts with. Eric again mentioned panelling but that's probably pushing the budget out. If I were to just put in more upright posts/railings what would the recommended spacings be?
You could add as many upright posts as you'd like, @bengroll. Regarding spacing, are you looking to comply with balustrade requirements or prevent a child from falling? If so, the gap between the railings should not be more than 100mm.
