How to hang plants on brick veneer wall?
Hi Experts,
I am putting some hanging plants and got Jack wall bracket (https://www.bunnings.com.au/jack-250mm-black-strap-wall-bracket_p3000245) now the surface I am going hook these brackets on is brick veneer. What nails I do I need because the surface is hard, do I need a power drill to drill it first to put any kind of nail? I could see in the customer review pictures people have mounted it on brick veneer surface or the material in between the bricks.
Thanks in advance,
Sid
Re: Nails for brick veneer
Hi @sidbose1987,
You'll need to drill into the brick and/or mortar and install plastic plugs. You can then screw into the plastic plugs to attach your brackets. These STAHL Masonry Kit 7mm Drill With 50mm Green Wall Plugs are exceptionally handy as they include the correctly sized drillbit, plugs and screws; it just takes the guesswork out of it.
You'll need a power drill with hammer function, such as the Ozito 710W Hammer Drill.
Here's a helpful step-by-step guide: How to drill into a brick.
Thanks @MitchellMc i bought the screws kit. But didn’t buy the power drill, is there a work around without power drill? I have that XU1 18V one but it doesn’t have that much power and hammer mode as well.
Unfortunately, you need a hammer drill to use a percussion masonry bit, which is included in the pack @sidbose1987. You could try one of these Multi-material drill bits in your drill. Do not run it at full speed; it needs to grind away at the material slowly.
No worries I think the right decision would be to buy one, so I will but the one you suggested is it good or good because of the price?
this is the other option, I can see the power difference, because I need to put in a hose reel as well in the front but the surface is same brick. Where would this double power be helpful?
https://www.bunnings.com.au/ozito-1500w-5j-rotary-hammer-drill-kit-rhd-1550_p0382377
It is good because of the price, and it will do just about everything you need it to around the home, @sidbose1987. The unit you've linked above is a larger type of hammer drill and is not needed for simple tasks like drilling into masonry. If you want a slightly more premium product than the Ozito, I'd recommend the Ryobi 800W 13mm Corded Hammer Drill.
Thanks @MitchellMc job done, and I guess the power drill was a great buy, I went with ozito 710w one, few pics
1. First one is my work.
2. Second one if from Bunnings review of the hook, what screws did he use? And as I have the drill bit which screws should I stock for future work
3. Third one is my alfresco. Now it has this metal edge, what’s the best method to have hanging plants there?
thanks
Sid
Hello @sidbose1987
Excellent work on attaching the Jack 250mm Black Strap Wall Bracket to your brick wall. In the second photo, I believe they used the Taskmaster 10-12G Snap On Screw Cap Black to cover the head of the screw. In regards to your alfresco, I suggest testing the edge of the eave first and see if it is attached to the timber frame. If it is, it would be better to drill into timber rather than drilling a hole in the metal edge of your alfresco. If the powder coating seal is compromised rust will begin to develop. The screws from the STAHL kit will work on timber as well, there is no need to use the plug when drilling into timber.
