How to grow transplanted frangipani?
cscott17
Hi I recently planted several frangipani cuttings. They have all been growing quite well. However when I took one of the cuttings out of its pot to put it in a bigger pot there were no roots on it. What could’ve happened
Re: transplanted frangipani
Hello @cscott17
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your frangipani.
It sounds like your frangipani cutting is focusing its energy on surviving and establishing itself rather than developing roots just yet. Frangipanis can be slow to root, especially if the conditions aren't quite right. This can happen if the cutting was watered too much, as excess moisture can cause rot or delay root development. It’s also possible the potting mix isn’t ideal; frangipanis prefer a free-draining mix.
I recommend using a mix like Yates 2.5L Specialty Potting Mix Cacti & Succulents, which is available at Bunnings and is perfect for encouraging root growth without holding too much water. When re-potting, let the base of the cutting dry out for a couple of days to heal over before planting it again. Once re-planted, water sparingly and ensure the pot is in a warm, sunny spot. With a bit of patience, your cutting should develop roots in time!
cscott17
Thank you EricL for your reply. I have already repotted it in a mix of sand and potting mix. Should I take it out and leave it as you have suggested.
Hello @cscott17
If you've already repotted it, I suggest leaving it so as not to stress the frangipani further. Just observe it for the next few weeks and don't over water it.
cscott17
Thank you. I will see how it goes.
cscott17
Hi again. I’ve repotted all the frangipani cuttings. How will I know when and if they have got roots, without taking them out of their pots.
Hi @cscott17,
If you gently pull up on them and they resist this motion, then you can safely say the roots have taken hold, but I wouldn't suggest repotting them for quite some time anyway.
I would suggest leaving them in their current pots for around 6 months at which time you can be confident that the roots have grown.
Hi @cscott17,
I should have mentioned that if they are in small nursery-size pots like these Garden City 100mm Plastic Grow Plant Pots, then you should wait 2-3 months before moving them to a larger pot that can sustain their growth for 6 months or so.
They will happily grow in the pots for ages/years, so stop checking to see if there are any roots.  Stop the watering because they will rot.  Frangipani are as tough as old boots in most cases.
Thank you. I have them in 200mm pots. Is that ok.
