I have cut down two of the bamboo clumps (I believe this is clumping bamboo) and cut down half of the other. I am applying Roundup on the leaves and new shoots. Is there a quicker way to rid myself of this problem...it's been planted adjacent to my swimming pool!
Hiya, do you know what ratio of blackberry killer to water or kero to use? I have just cut down clumps and put 20ml to 1 litre of water. Not sure if that is enough, will know in a couple of days I suppose? Thank you.
Hi @oakesash,
Welcome to the Bunnings Workshop community. We're really pleased to have you join us and look forward to reading about all your projects and plans for around the house and garden.
The ever-knowledgeable @Noelle recommended earlier in this discussion to mix up a solution of one part glyphosate to six parts water.
What product did you use and did you follow the directions on the label?
I used the Yates Blackberry & Tree killer - it has a number of different options for directions and ratios dependent on plant, but there is no mention of bamboo. However I have been advised by many, including this forum, that this product is excellent to eradicate bamboo. I used one of the recommendations, which was 20mls with water. But there are other stronger dilutions suggested using water or kerosene etc.
Thanks, Jason.
Hello @oakesash
I've been looking at the Yates website regarding the mixture of Tree and Blackberry killer and water/kerosene and could only find the following below. You are correct that there are no references to Bamboo. As an alternative to chemical means of killing the root, I also suggest using a Cyclone 1650 x 25mm Hex Fencing Bar to break up the root of the bamboo tree. It will take a while but at least you'll be able to take immediate action and any possible leftovers can be poisoned off.
Below are the mixing ratios as suggested by Yates:
