How to attach watering system to raised garden bed?
Is there a way of clipping water pipes to the galvanised raised beds?
- Labels:
Gardening
Plumbing
Tools and Materials
Re: is there a way of clipping water pipes to the galvanised raised beds
Welcome to the Bunnings Workshop community @SeanDunne. It's great to have you join us, and many thanks for your question about attaching water pipes to a raised garden bed.
The first method that comes to mind would be using galvanised saddle clips and pop-rivetting them to the garden bed wall. If you can provide a little more detail on the size of the water pipes, I trust our members will have some other innovative solutions for you.
Let me know if you think that would work, as it seems like it would be a neat attachment method.
Re: How to attach watering system to raised garden bed?
I have galvanised raised bed with irrigation installed. A simple riser with a saddle clip does the job. Photos attached for your reference. This have been installed 4 years now and works a treat. We can used the programmed sprinkler system or click on hose, by use the turn valve, thanks to my Dad and ingenuity 😀
On off valve to a hose connector
Sadle clip and main line irrigation
Hello @Grub80
Thank you so much for posting your irrigation setup. I'm sure @SeanDunne will appreciate the photos you've shared. I see you and your dad used Zenith 8G x 12mm Galvanised Hex Head Metal Screws. That's an excellent way to hold the saddle clip in place. Have you had to change any of the irrigation pipes during the four years of operation? Any other tips or information you can share about your irrigation system would be much appreciated.
Subject | Author | Posted | |
December 2023 | |||
January 2024 | |||
July 2021 | |||
October 2021 | |||
November 2021 |
