How to add watering system for climbers?
amichaelmedia
Cultivating a Following
Any suggestions to keep these climbers going over summer with an irrigation setup? Drip feed or spray?
I did have a soaker (nylon) set up along fence put the hose split from weathering
Each screen is 2m 12m in total
Re: type of irrigation
Hi @amichaelmedia,
Thank you for your question about irrigation for climbing plants.
The best type of irrigation for plants like this is drip irrigation. Drip irrigation will deliver the water directly to the base of the plants where it is best put to use.
Running some 13mm poly pipe along the fence line with a dripper at the base of each plant will make watering simple.
Check out How To Plan An Irrigation System and Installing Irrigation Sprayers And Drippers for some guidance.
