Garden walkable hole cover
topmarx
Hello
I am doing landscaping and have a section of the garden that is just off a tiled patio, the goal is to put artificial turf down so it can be used as a BBQ area. The challenge is that in the far right corner is all the plumbing and water mains, inc sewerage access. The other challenge is that these pipes are probably 700mm below the patio ground level, raising all these is expensive.
The thinking is to build a retaining wall, rectangle around the water/sewer mains, either using sleepers, or bricks as I have a load of bricks left over from a recent renovation. This will create a 900mm x 1700mm rectangle. The idea is then to fill this section of the garden with soil so that it is just a simple small step down from the patio.
So the remaining challenge I have is how to cover the rectangle retaining hole. I want to cover it so that it can be walked on and ideally covered with artificial grass like the rest of this section so it blends in, and hides the access to the sewerage system.
I am looking at two options:
Finding a galvanised mesh grate, but it is difficult to find the required 900mm x 1700mm size, and having a custom grate build looks very expensive. I am also looking at resin/fibreglass options but not having much luck.
The other is to build from wood timber, having slats going from the outer edge to the edge of the bricks, and then slats going the other way, from internal edge to edge, so the wood grate sits onto the bricks.
Looking for any help on finding pre-building grate options, else building a grate?
Thanks Marc
Jewelleryrescue
Kind of a Big Deal
Re: Garden walkable hole cover
Hi @topmarx
A good  product to use in your situation is  Light weight durafloor  Cement fibre sheeting
How  much lighter than regular cement sheeting actual weights  not meantioned.
You may need a timber frame under it to then sit on your brick work and it may be advisable to make the cover in sections as 1700mm is a long span for any cover could be awkard and heavy.
I might also consider using red  or yellow tounge flooring if under coated and  paint sealed will withstand weather conditions as long as  paint holds  And easier to tack  artificial  lawn to. being  timber.
Ps  a forever fix Go with bricks I would double brick it and also put in retaining wall ag lines and gravel over ag line inside the brick wall dirt side.
They are allready at a natural  ground level the services.  And you are  making a pit of sorts so why not channel the Ag line and make a water exit point from inside the pit on the down hill  exit point for all waters.
Hope this  helps
