Hello experts,
I am looking for creative ideas to landscape my front garden. The sandy soil in Perth makes it challenging to grow colorful plants in the beds, so I am exploring alternative options.
Here are some key points:
1. I do not want to retain the existing palms but One of the palms had already fallen, leaving a stub, which is difficult to remove. I am concerned about how to manage the removal of the remaining palms effectively.
2. I have considered adding a pond, but the electric meter at the corner requires accessible space, so I need to work around it. Kids would love a pond or any water body.
3. Open to using stones or pebbles (like in the attached photo) but am unsure how well they would blend with the rest of the garden.
I would appreciate any suggestions or recommendations on how to approach this and design the space effectively.
Thank you!
rest of garden for reference
stone /pebbles idea
Hi @kingj
Merry XMAS
Your Palm stumps will become soft and rotten soon enough and hitting it with a matock should chip away at it untill it is at ground level then it is up to you how deep you want to go getting more out. As it rots away other plants will take its place if you plant them.
Given Perths sandy soil Consider making raised garden beds say 300 to 400mm this will allow you to add organic soil and plant any thing you want. Perths climate semi tropical?
You can also use a hard shell plastic pond shape for your raised fish pond. I like using pool fencing laid across a pond as it is designed as a pool barrier. Going horizontal is the same as vertical if the water is cover and at the same time allows pond viewing in saftey.
Hi @kingj,
As @Jewelleryrescue mentioned, using a mattock to break down the palm stumps should make the removal process easier as they rot. If you're looking for a more immediate solution, you could consider employing the services of an arborist to remove the existing stump and manage the removal of the other palms.
For your front garden, considering Perth's sandy soil, raised garden beds are a great idea. You can fill them with a mix of organic matter and quality soil to provide your plants with better nutrients and moisture retention. Adding a variety of colourful, drought-tolerant plants like succulents, native Australian plants, or ornamental grasses can create a vibrant and low-maintenance garden.
Regarding the pond, I think it would be a great addition, especially for the kids. To work around the electric meter, you could position the pond in a corner or along the side of the garden, ensuring that there's still easy access to the meter. If you choose a smaller pond, you could even consider a raised one, which would allow you to incorporate stones or pebbles around the base for added texture.
Using pebbles in the garden can work really well as a landscaping feature. Just ensure you choose a type and colour that complements the rest of your garden. A gold western pebble or scoria could suit the look. You could create pathways or use pebbles as mulch around the plants, giving the garden a clean, modern look. It would also help with drainage, especially in sandy soil.
Here are a couple of helpful guides: How to plan a garden makeover and How to give your garden a makeover.
