Workshop shed build
Kiwifr33
Having an Impact
Workshop shed build
Some people go away for their holidays... and then there’s me, who takes four weeks leave to build shed.
There was sort of a plan - a couple of drawings and some framing layouts, but nothing spectacular. After a year and a half of collecting unwanted timber, house wrap, insulation, Colorbond, trim, OSB and screws from local house construction, I was ready to go. Purchased some framing timber, flooring and timber for the subfloor, five sheets of OSB and the Ryobi 3 piece nailer / stapler set. Add two secondhand windows and assorted flashing and fixings, stir in a dollop or door hardware and cap with the 5.1m x 240mm LVL bearer I found on the side of the road.
BFB706B7-229B-48C9-8E7A-E45E9E015C02.jpeg594EDED6-640E-42BF-8DE8-1E1F5B911F5E.jpeg607A3BFB-39B0-4740-A322-F01AB7CE9DCA.jpeg518F7902-9B8A-403C-A0C6-12AF46491FF9.jpeg93DE780D-2C8A-4F23-8F1B-E0FE04D337B5.jpeg7F26CADC-061B-4429-A0E3-1A0BB0794F7D.jpegB133C3B5-2106-49FD-8790-890B8F5552F2.jpegNearly there.Nearly there.37EFB3AE-820F-4C02-86F7-7C0BA78FAA3B.jpeg966FA309-AF5F-4A95-A7F6-4D75319FBAE1.jpeg
Kermit
Re: Workshop shed build
Good one @Kiwifr33. Thanks for the update.
But wait! There’s more...
Found a cabinet on the side of the road on Fathers' Day!Found a cabinet on the side of the road on Fathers' Day!Eastern endEastern endWestern endWestern end
Great project, a year later this question may be too late but where in Australia can you source OSB? I have looked everywhere.
Brad
Or in skips wherever they’re slapping on a new suburb near you...
Bundaboy
Having an Impact
Thanks Brad,
There is something wrong with that link (does it work for you?), however I found something similar - special order huh? No wonder I have never seen it.
Thanks Kiwifr33, I wish! LOL.
Truth is I have never seen it used around here, and I always have a good look at new building sites. Not sure if that is down to regulation or availability. I am in a Fire zone, not sure if that is relevant or not.
We're in a fire zone as well, and if they took any notice of grass fires, the new burbs would be too! That said, it’s common as muck here in brick veneer construction: goes over the framing and has the building paper attached. Though weirdly, it’s disappeared from the Bunnings store page - maybe try a Trade store?
OSB is available in 2 different sizes in most Qld stores
OSB PANEL++2500X1250X12MM and OSB PANEL++2500X1250X18MM
its a CSO (Customer Special Order) but easy to get :smile:
Check with your local store\s and Im sure they can get it in for you if your after it
Brad
I think not all products are available off the shelf in all states. Well that proves it.
