What is easiest way to shrink Cobra heatshrink tubes?
Marcusfrumpus
Is a match a suitable way to cure heat shrink?
Re: how is easiest way to shrinkcobra heat shrink tubes. A match?
Hello @Marcusfrumpus
Welcome to the Bunnings Workshop community, Thank you for joining us and sharing your question about Heat Shrink tubes.
If you are only doing a few jobs with the Heat Shrink it would be practical to use a match. However, if you are doing many jobs I suggest using an Ozito 2000W Variable Temperature Heat Gun. This will allow you to heat shrink the tube more efficiently and uniformly. If you are currently working on a project, please don't hesitate to post. Our members will be more than happy to provide advice and information should you need it.
Please keep us updated.
Match worked well, only needed on two tubes. Incidentally tried on some other plastic  and they melted to fit.
Probably the best is a hair dryer, don't use matches you will just burn the tube rather than shrink it.
Great tip there @David_B! I've also found it's a bit hard to get enough heat from a match without burning the heat shrink.
Many thanks for joining us here at the Bunnings Workshop community. We look forward to hearing all about your projects and plans around the house and garden and would encourage you to let us know any time you need assistance or have something to share. I trust you'll also find loads of inspiration and amazing projects to build, which our amazing members have contributed.
