Looking for a Suitable Tool
Prof
Amassing an Audience
I have an MDF timber box (describing it simply) that has a 200mm. hole cut out the bottom..The bottom panel thickness is 25mm.
I want to increase the hole to 250mm. in diam. The internal box base is approx. 300x300.The depth of the box is 150mm..
Normally a simple enough job, but in this instance I can only reach the hole by going into the box because it's a part of a larger construction..
There's not enough room inside the box to use a router or jigsaw, so any ideas what sort of cutting tool I can use..
Prof
Re: Looking for a Suitable Tool
Thanks Wayne...
I'm glad to hear that the multi-tools will cut through the MDF very easily..
There is a fairly narrow blade that comes with the kits which should do the job..It will be just a matter of making a lot of cuts and finishing off with sandpaper..
Prof
Thanks Brad...
Yeah I've use those bits before and they are not very effective
Rusty-Saw
Cultivating a Following
Can you get a hole saw on a power drill in there, if you can you will need to secure a scrap piece of wood onto the face and using the hole saw cut into that and continue through into the MDF, once done remove the scrap and you now have a neat round hole, sand to smooth, done. You need the scrap as a guide for the hole saw as you can not use it to expand an existing hole.
Prof
Are there hole saws 250mm. in diam.!?
Rusty-Saw
250mm is a big hole saw, if they do it would be expensive, sorry I must have misread the size you are trying to work with.
