How to waterproof and verminproof the base of shed wall
RRhys
So I have an old shed that was put together poorly.  I want to convert it into a studio for my darling spouse. First step is waterproofing and verminproofing the walls (then insulate, internal walls etc).
As you see from the photos, there is flashing just sitting under the wall.
So I'm thinking that I need to rivet the flashing to the wall, sikaflex under the flashing and maybe then expanding foam between flashing and wall on the inside?
Any tips on the project generally - walls, membranes, plastering much appreciated!
 Here are a couple of pics of the current situation.
Re: How to waterproof and verminproof the base of shed wall
Welcome to the Bunnings Workshop community @RRhys. It's great to have you join us, and many thanks for your question about waterproofing a shed.
You’re on the right track with your initial ideas. Start by securing the flashing to the base of the shed walls using corrosion-resistant rivets or screws, ensuring the flashing extends slightly over the ground or slab to direct water away. Apply a generous bead of Sikaflex or a similar sealant underneath the flashing to create a watertight seal.
On the interior side, use expanding foam to fill any gaps between the flashing and the wall to prevent vermin from entering. If you have a significant vermin issue, you might like to incorporate wire mesh, which they can not chew through. For additional protection, consider installing sarking over the interior walls before adding insulation and internal cladding. When it comes to plastering, use moisture-resistant plasterboard or panels to withstand any residual dampness.
