Hello All,
First time post.
The carport has leaks which I almost stopped with Sikaflex 11FC but drips are back and when poking around, the bead easily peeled away. What sealant should I try next? It needs to be adhesive as it's being applied to the roof interior and needs to bond to metal and wood - some sort of aggressive silicone?
Jamin
peeled 11fc bead
peeled 11fc bead to the left of beam / 11fc in situ to the right
Welcome to the Bunnings Workshop community @Jamin1. It's wonderful to have you join us, and many thanks for your question about sealing a roof.
Sikaflex 11FC is one of the best sealants, and there's not really anything I can suggest that would be better. I think the issue here is that you need to seal a leak from the outside and not the inside. Is there something preventing you from doing this repair on top of the roof?
