Is it possible to restore the drywall without replacing the plasterboard? The board is stained with glue residue that the previous owner used to adhere a garage cabinet board to the wall.
Hello @ivanptr
I suggest sanding the surface of the plasterboard to get rid of the glue residue on the surface. If there are dep sections that need to be filled, I suggest using Gyprock CSR 2.25kg Less Mess Multi-Purpose Joint Compound in combination with a Craftright 280mm Plasterers Trowel. Your goal is to fill the dips and damages at the same height as the wall or just a little bit over. This will save you from sanding a great deal off plaster off once the filler cures. Once the plasterboard has been repaired you can now paint it to whatever colour you like.
Hi @ivanptr
Yesterday I had exactly the same project to do before installing VJ panel board to the wall. I used a multitool with a wide scraper blade fitted to clean all the old glues and silicones off the wall. My blade has also been sharpened which makes a big difference.
