How to build a concrete pad with 2 sides against existing sheds?
Char1991
Hello
I am installing a DIY concrete pad for a horse washbay that will be 7 x 4m.
I am getting the concrete delivered to save my back a bit but will be doing the rest myself. I have researched and learnt about the formwork, reo mesh, reo chairs etc.
However, my question is, as 2 sides are against existing sheds, i assume i don't do any formwork on those sides as the sheds themselves essentially form it. Is there anything i should spray on the colorbond of the sheds to protect against the concrete or anything? It is just a tack shed and a storage shed as per drawing (not to scale).
Re: DIY Concrete Pad with 2 sides against existing sheds
Hello @Char1991
Thanks for sharing your question about your concrete pad installation. For total protection of the shed, I suggest building form work right up against it. In this manner the concrete won't even be touching the shed. Another option is to paint the bottom of the shed with Gripset Betta 1L Waterproofing Membrane Bitumen Rubber. The membrane will protect the shed from any corrosive effect the concrete may have on steel.
My best advice is to make sure that the pad has a slope in it to prevent water from pooling on the surface, always provide a drain or run off for the water and make sure to cover the surface with plastic to slow down the drying time of the concrete. This will prevent the surface from splitting or cracking.
Char1991
Hi Eric
Thanks very much. I will get the membrane and paint the shed as i would prefer the concrete butt up against the shed to avoid it becoming a channel full of horse hair, manure etc.
Can you please let me know what is the best products from Bunnings for the formwork and to screed, spread the concrete etc? Keep in mind the width of the area is 4m so whatever will make it as easy for me as possible.
Thank you
Re: How to build a concrete pad with 2 sides against existing sheds?
Hi @Char1991,
This is a pretty big slab of concrete, which will be a mammoth task alone. At 100mm thick, you are looking at 2.8 cubic metres of concrete which will weigh approximately 7 tonnes. When you are dealing with this weight of materials, with a timeframe that starts ticking the second the concrete leaves the truck, I'd strongly suggest you get a helper or two.
With your existing sheds, are they sitting on concrete slabs and your new slab will butt up against them? Or will the concrete run up to the frame and the corrugated sheeting that sits in front of it? If you have some photos of your existing shed's foundations, this will certainly help me offer my best advice.
If the concrete doesn't butt up to existing concrete slabs, I would need to see it to offer advice.
If the new slab will butt up to the old slabs, you can use them as formwork to pour your concrete against, but you will need to allow for expansion. Attaching Sika 10 x 100mm x 25m Abelflex Expansion Joint Filler Foam to the outside of the existing slabs is essential for this.
I have seen a variety of different things used as formwork with 90x45 framing and 100mm fence rails being common choices. You'll want the top of the formwork to act as a height marker for your concrete so you can screed off of it, so look for a material that is the same thickness as your slab.
You'll want your formwork to be well supported along the full length of each side to make sure the pressure doesn't bow the edge of the slab, so you'll need to drive a star picket or timber stake into the ground every metre or so along the outside of the formwork and screw it in place. These Growies 50 x 25mm 450mm Hardwood Garden Stakes or these Jack 45cm Premium Steel Ultraposts are good options.
Once the concrete has arrived, you're on a tight timeframe, so you'll need the right tools to ensure things are spread quickly.
You'll need a d handle square mouth shovel, such as this Saxon Square Mouth Shovel and a Masterfinish Placer Rake to move your concrete around.
To screed the concrete, you'll want the longest screed possible. This Masterfinish 3000mm Screed is a good option.
You're also going to want a long spirit level, at least 2 metres long to ensure everything is falling away from the existing slabs as intended. You can set your formwork as a guide before the pour, but you'll still want a level handy while it is going on to ensure the concrete is falling as intended and there are no low spots that will accumulate water.
Once everything is screeded, you'll need a Masterfinish Telescopic Handle and a Masterfinish Bull Float so you can smooth the concrete without walking on it.
You'll then need a Masterfinish Cement Edger to edge up against the formwork, so you have nice, rounded edges instead of sharp ones.
Depending on the finish you are looking to achieve, you may also need a Masterfinish 16" Masonry Float to get an extremely smooth finish, or a Masterfinish 900mm Finishing Broom for a broomed finish.
As I'm sure you'll see, there is quite a bit to it and you're going to need quite a few tools to ensure things go smoothly.
