The shade i want is ABSCO
Hi @aster,
We offer a Shed Assembly service, however you would need to ensure there is a foundation in place as this is not part of the service. This service can be organised through your local Bunnings Special Orders desk.
If you need assistance with a foundation, you'll need to contact a concreter. You can use a service such as HiPages or True Local to find a concreter that operates in your area.
Let me know if there is anything else I can assist with.
Hi @aster,
I just thought I'd add if you're interested in constructing your own concrete foundation for the shed, it’s definitely possible and can provide a strong, stable base. You’d need to ensure that the foundation is level and properly sized to accommodate the dimensions of the shed. The process typically involves preparing the ground, setting a formwork, and pouring the concrete to create a solid, durable surface. Once that’s set and cured, you’ll have a sturdy foundation to affix your shed securely.
For raised floors, you might want to add a frame or platform on top of the concrete base to raise the floor above ground level. Alternatively, you can add an internal floor to your shed over the concrete base.
Here are a couple of helpful guides: How to pour a concrete slab and How to install a shed floor.
