We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
As part of Bunnings' timber cutting service, do they also include circular cuts?
Hi @kanga25,
Thank you for your question.
Unfortunately, Bunnings cut shops are only set up to do straight cuts.
If you want to do a circular cut, you will unfortunately need to do it at home.
This can be done with a few different tools such as a jigsaw, router or a holesaw.
You might like to have a look at Tool Guide: What Is A Jigsaw? and Tools 101: How To Use Power Saws for some further information.
hi,
Can bunnings cut 2200x600 into 2200x400, straight cut?
Welcome to the Bunnings Workshop community @pankajtanwar23. It's marvellous to have you join us, and many thanks for your question about our cutting service.
Unfortunately, due to their thickness, we are unable to cut benchtops down to size. You might like to consider using a circular saw to do the job at home. Here's a helpful guide: How to cut a benchtop. If you're unable to cut the benchtop down at home, then you might like to consider a made-to-measure option or enlist the services of a professional to complete the work for you. You can see our helpful team at your nearest store's Special Order desk to place an order for a custom benchtop.
Hi, I'm hoping this isn't a rude question but does the Cutting service ensure final product is square? I'm making a bookshelf & tv cabinet to a custom size but don't want to buy all the saws etc (already have drills & sanders). If the cutting service has a "near enough is good enough" approach, I'll get someone to cut it for me so it's along the grain for the right pieces and square so I don't have to do anything other than assemble & sand.
Hello @lynnyd
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about your bookshelf and TV cabinet.
Your question is perfectly fine and is not rude at all. I've answered this question many times before in another post. Unfortunately, the shop saws are not designed for precision cutting some can be off by 2mm other as large as 5mm.
However, I propose speaking to your local stores saw operator and discussing with them your plan. But if it really needs to be precise then I encourage you to have a look at circular saws. This tool may seem daunting at first, but if you get enough practice cutting timber you'll wonder where it's been all your D.I.Y. life.
There is also the option of using a regular hand saw, my grandfather built beautiful furniture with just a hand saw. It might take longer, but your cuts will be precise.
Here is a handy guide that will help: How to choose the right power saw for the job by @Adam_W.
For the timber cutting service.
Can a MDF board be cut to a sepcifice size
width: 56cm
Length: 131cm
Hi @max_speed,
Thank you for your question and welcome to the Bunnings Workshop community.
Yes, I can confirm that our cutting service can cut MDF to the above-mentioned sizes.
If you have any other questions, please don't hesitate to ask.
Does Bunnings cut decking into different sizes, I need 18 total and 3 different lengths?
Evening @Stewyj26
Bunnings can cut timber into lengths, however they do not cut it for exact meausurements. My suggestion is to go over on the distance of the lengths you want and then trim them when you get them home. There is also a fee depending on quantity, If you have a friendly chat to your local Bunnings timber section they will sort you out. They have helped me out several times
