Can you install a shed on a slope?
jonathan_d
Hi, new to this forum, thank you for having me! I have recently moved house and we seem to have much less storage space for outdoor type things such as golf clubs, tents and our lawnmower. There is one existing shed on the property but it is not really sufficient for all our needs. I am thinking of installing a metal shed, perhaps an ABSCO shed, but we are not spoiled for choice of location. We had thought of putting a long thin shed down the side of our house but have read that in NSW (we are in ku ringai shire) you need to keep sheds 900mm from the boundary and this would not work as our side pathway is only maybe 1800mm wide. There is another area in a C shaped space on the south side of the house where you could perhaps put a skillion roof shed with the roof sloping away from the house wall. I will provide a photo. This area as you can probably see is not flat, sloping down  towards the wall of the house, and so if I used gravel and skids as the foundation I would need to compensate for this with timber sleepers or concrete blocks or something like that. Or use a sort of planter box like structure and fil it with gravel? I have a few questions: 1. Is it possible to make this work in this location? 2. Should a shed be off the wall rather than touching it? And by how much? 3. What would the best foundation be given that I don't want to put a slab of concrete here? (Ultimately we might not have the shed there forever). Thanks, hope my idea is not too silly!
Re: Help needed deciding about shed location
Hello @jonathan_d
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your shed.
It’s great that you’re thinking through the best way to maximize your storage space. In NSW, including Ku-ring-gai, small sheds can often be installed without council approval if they meet certain standards, such as size limitations and boundary setbacks. Since your side pathway is only 1800mm wide and NSW generally requires sheds to be 900mm from the boundary, it may not be a suitable location. However, the C-shaped area on the south side of your house could be a good alternative, as long as it meets the necessary regulations.
When it comes to positioning the shed, it’s generally best to keep it slightly away from your house rather than directly against the wall. A gap of at least 50mm is often recommended to allow for air circulation, prevent moisture buildup, and make maintenance easier. Checking with the Ku-ring-gai Council would be wise to ensure compliance with any local rules.
Since you don’t want to pour a concrete slab, I can only suggest a timber frame foundation, it is simple, effective and can be built heavy enough to anchor the shed in place. If the slope is significant, using sleepers or concreted blocks to level the area could work well. Before proceeding, it would be a good idea to confirm the specific requirements with the Ku-ring-gai Council to ensure your shed placement and foundation choice comply with local regulations.
Hi @jonathan_d
I would go with a Skillion roof shed within that pictured C-shaped area with the high-point to the right. If you allow a reasonable space between it and the house wall, you could use that for storage of garden tools to save shed space.
If you level the area out, then 75mm treated pine sleepers would provide a good base to fasten the shed down to on all four sides. Its a cost effective DIY solution I have done several times.
Morning @jonathan_d
Welcome to the community :smile: There aere a lot of threads in here with shed type questions and also projects.
Instead of a shed, how about a lean to? This is open on the front generally with the rear attached to a structure but using the structure as a support.
You could have it down the side of the house so you cover the 900mm from teh house with a roof, still have access and can move large items in and out as theer is no fixed doorway. (I park my lawnmower in a small tin shed with no door and itr may get a little rain but mostly dosnt)
You could have a clear patio blind across the front to keep the water off and also make it look tidy.
Other then that the C area of the picture with a shed would work with a metal shed tho I usually think of them as a heat sink :smile:
I just had a look in google for a "thin shed" and several rocked up at 780mm wide. Depending on how the doors are configured you could use these down the side of the house.
Thanks Eric,, that's very helpful. I am probably leaning towards the c shaped area but am waiting for council to get back to me. I am interested to know what you mean by a timber frame foundation. Could you provide more information or a link to another post that has a diagram etc
Jonathan
Thanks so much for your reply, @Nailbag. When you're talking about sleepers to anchor it down on all four sides do you mean a row of sleepers sitting next to each other? Or are there other possible solutions? I have attached a poorly drawn diagram, I think you might be talking about "B" in the picture I've drawn but I had two other pictures in my mind.
 thanks again, jonathan
Re: Can you install a shed on a slope?
Hi @jonathan_d,
@EricL would be referencing a base constructed of treated timber, similar to this Absco Sheds 1.52 x 0.78m Timber Flooring Kit. Bear in mind this is considered a lightweight base and not suitable for high-wind locations. Alternatively, you could go with @Nailbag's idea of using the sleepers, and I'd suggest he was meaning option B so you have a solid and level internal floor.
Yes @MitchellMc and @jonathan_d the solid floor of sleepers was the intension.
Instead of sleepers could I make sort of mini deck with the lower side sitting on paver blocks or similar, and the upper side sitting on pedestal feet which could be adjusted for level-ness. For the joists I could use some sort of treated 70x35 timbers and have a joist going across every 60cm under some 2.4m treated pine decking boards. Then the shed would be fastened (screws?) to the "deck". In the C shaped area it should be relatively shielded from wind so presumably the weight of this deck should enough to hold the whole thing down onto the gravel base. Is this a viable alternative? If so, which timbers would you recommend?
Hi @jonathan_d,
That's certainly an option in areas that don't experience high winds. I'd suggest using 90 x 45mm for your joists and frame rather than 70 x 35mm, as they are better at spanning distances. You'll still need support in the middle of them to span the 1600mm.
