Timber decking for a pathway to the front door, lined with PebbleLock and pebbles.
I just finished decking this entry path and it looks amazing. It wasn’t as hard as I thought it would be, which has given me the confidence to start on the longer path.
I cut the slats to 80cm long and waterproofed the underside, then I used decking screws to screw them on. I already had a frame from the PVC plantation shutters left over, so I used that. I then bought some PebbleLock to keep the sides neat when I went to add the pebbles.
I then sanded the whole path with 80-grit sandpaper and then whitewashed it.
Finally, it was time for the fun part of styling and buying plants and pots to add a pop of colour.
Resident Bunnings D.I.Y. expert Mitchell has compiled this step-by-step guide on How to build a deck, including a full list of tools and materials and video.
Experienced Workshop member Adam has also shared a step-by-step guide How to build a decking boardwalk.
Workshop member oninpena built this low-level composite deck over concrete and soil after getting advice from the Bunnings Workshop community.
Community member Nat also benefited from advice from the community and built this low-level composite deck over a concrete slab.
Check out our Top 10 most popular deck projects and Inspiring low-level deck builds for more ideas and inspiration.
Aftenoon @selva
Thats a nice looking pathway It certainly lifts the front yard up!
How is it holding up to usage?
That's a very enlightening (to me anyway) use of products. I haven't heard of Pebble Lock, but it would have been handy in our last home. And using PVC angle as side framing. Very impressed with how it has all come together.
