Hi all,
Love the forum and have almost always been able to find the answer I need… but not today.
Fairly simple: I’m looking to patch some plaster / drywall adjacent to a shower recess at my girlfriend’s place that has become a little damaged. I’ve plastered, done joints, etc, but never in any wet rooms so it’s new territory for me.
Going to scrape away rust if any, clean the metal with acetone, and remove the flaking paint to see if the damage is more extensive, but it looks pretty superficial (fingers crossed!).
What products should I be using to patch any damage to the wall (before applying paint)? Assuming / hoping I don’t need a whole sheet of aquachek here!
Arki
Hello @Arki
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about patching plaster in your bathroom.
Would it be possible for you to post a larger photo of the wall, I'm just a little bit confused in regards to the damaged walls relative position to the shower. Is this inside or outside the shower itself? Your proposed steps to investigate the damage is excellent. If the damage is superficial then sanding the rust and applying rust converter should fix the issue and using a kitchen and bathroom rated primer should provide the area with adequate protection. If filling is necessary, I recommend builder's bog to fill in any gaps.
Many thanks for getting back to me @EricL with your helpful reply!
Unfortunately I’m not on site at the moment, but I marked up the following to illustrate where the photo was taken and the different surfaces involved.
The patching (of the drywall) is JUST outside the tiled shower area (to the left in the photo) per below.
Sounds like builder’s bog will be the right filler for this purpose (and presumably better suited to these wet-adjacent areas than the standard gyprock base and topper I’d usually use elsewhere) before I prime and paint as you suggest with kitchen/bathroom rated products. Will of course scrape off loose paint, remove rust, clean, and sand first as recommended, ta!
I’ll head in to my local Bunnings tomorrow, and appreciate your help with this.
Arki
Hi @Arki
Thank you for sharing the extra photos. Once you've patched the damage, I propose putting a larger bead of silicone on top of the tile for extra protection.
