can I replace my old tub with this corner one?
sirano1004
Hi, I'm planning to replace my old bathtub with this new one. I assume there won't be any tiles underneath the current tub, but since the new tub is larger, I plan to cover that area without adding tiles.
However, I have a concern about the water tap. My current tub is 46 cm high, and the center of the water tap is located at 62 cm. The new tub I'm considering has a height of 58 cm, leaving a 4 cm gap between the top of the tub and the water tap.
Would this setup work, or should I consider a shorter tub? Alternatively, should I look into relocating the water tap? I'd appreciate any advice.
Re: can I replace my old tub with this corner one?
Hi @sirano1004,
Thank you for your question about installing a new bathtub.
You would need to use the Rick Mclean's Bathware 1500mm Modern FB13 Left Hand Corner Bath based on the orientation of the bathtub in your photo.
Typically, a bathtub like this will be installed before the tiles, so the tiles would not run underneath it. If this is the case, you will need to either fill the gap where there are no tiles or have the existing tiles cut so the tub will fit in the space. Of the two options, cutting the tiles will have the tub sit lower and considering the tap location, this is likely the better option.
You would need to check with a plumber whether this tap height is suitable and fits within the relevant Australian and New Zealand Standards.
I can't say for certain that this setup will work as I do not have access to the relevant standards. As you'll require a plumber's assistance for this installation regardless, I'd suggest speaking with them to go over the possibilities. While it is likely best you relocate the water tap, they may be able to offer a solution that will work for you.
Allow me to tag @Nailbag and @Dave-1 to see if they have any thoughts or advice to offer.
