Why did changing bathroom sink jumper valve cause water pressure to drop?
gbullo
I just changed the jumper valve on a bathroom sink cold tap which was dripping and now the pressure has dropped on both the cold tap and the hot tap paired to it. I have dual sinks and the other still has good pressure.
The old jumper value was brass and I would say original (12 years) the new one I bought from you was 13mm jumper valve.
I have change quite a few over the last year or so and this is the only one to lose pressureIMG_8412.jpgIMG_8413.jpg
Noyade
Re: changing bathroom sink jumper valve cause water pressure to drop
Hello @gbullo
I had a similar experience last year after changing a vanity tap washer.
Reduced spout outflow on both hot and cold.
Couldn't fathom it.
Then I discovered the spout had a metal filter at the end. Changing washers disturbed material that got caught and blocked the outflow. Once removed, cleaned and replaced - outflow pressure restored.
Just a pre-wine thought.
Cheers.
Thanks Noyade
I was going to test that today as both hot and cold were affected pointing to something in the mixer sprout.
I am guessing I need to start with the end attachment on the sprout.
Clean filter - flow restored :smile:
Nice one, @gbullo, and welcome to the Bunnings Workshop community.
Was it some of the valve stuck in the spout? I was going to mention that it looks like you lost quite a bit of the one in your photo.
Many thanks for the update, I'm glad you got it sorted.
Yes Mitchell - lots of little pieces - all the big ones I got out with long nose plyers.
