Anyone can recommend Solar security light with sensor that can work with gutter mount . We are thinking to use gutter mount like this so we dont hv to drill holes
How many lumens should the security light at least has ? the brighter the better we reckon
Hi @ivanptr,
I am unaware of any solar security light with a gutter attachment bracket. If you need to drill into a masonry surface, I recommend you check out this helpful step-by-step guide: How to drill into brick. It's quite an easy process, and these Stahl masonry kits are great as they include the drillbit, wall plug and fixing screws.
Solar-powered security lights typically have a lower lumen count than a 240V version. Something along the lines of the 2000lm version would provide a sufficient amount of light for a courtyard or short driveway.
