What shower rail kit uses holes 800mm apart?
Waz12
Hi I'm replacing shower rail kit and my existing holes are 800mm apart. Do U have anything to suit this
Re: What shower rail kit uses holes 800mm apart?
Hello @Waz12
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thanks for sharing your question about replacing your shower rail.
I suggest having a look at the Caroma Essence Multi Function Rail Shower WELS 3 Star 9L/min. This is one of the units that are still mounted at 800mm. I've placed a diagram below to give you a better idea of its' measurements. Please note that this is a special-order item. You'll need to go to your store's special orders desk to order one in.
Waz12
Thanks Eric I have searched high and low for this!    Now I also need the other bathroom rail replaced and spacing for this one is 570mm . Can you help?
Hello @Waz12
For your other bathroom I suggest using the Methven Futura MK2 Rail Shower WELS 4 Star 7.5L/min. It has a variable mounting post at the bottom for easy retrofit installations.
Please make sure to read the mounting instructions very well before fixing the rail into place.
Waz12
I don't think this would work. 600-20 to the centre of each post would make it 560mm to each hole
Hello @Waz12
My apologies It is short by 10mm. As an alternative, I suggest looking at the Revolution Self Cleaning Hand Held Rail Shower Chrome. It has a rail length of 715 and has adjustable post positions as well. Please note that this is a special-order product as well.
