Wardrobe and storeroom shelves
Baggs
Having an Impact
Hi Everyone,
Just another small project I've done at the new place.
I added some extra shelves to my wife's robe and fitted out the storeroom too.
Materials
42x18 primed pine
50mm timber screws
30mm timber screws
liquid nails
Melamine shelving
Tools
Drill
impact driver
drop saw
multi tool
circular saw
square
clamps
level
Steps
Step 1
Started off putting the 2 vertical melamine panels in.
One up against the existing shelf and one in the center to divide the new shelves. I used a multi tool to cut the skirting to allow the vertical panels to sit back against the wall.
Then worked out what spacings we wanted and found what studs were in the area.
cut the 42x18 pine to size and used liquid nails and 50mm screws to fix in spot.
Step 2
Once all the batons were up it was time to fill the screw holes, run some gap filler around and paint. So much easier before fitting the shelves.
Once all dry it was time to cut the shelves in.
Grab a big square to check your corners and cut the melamine to suit. This can be a bit tricky to get right but just take your time.
Plus if there is any gaps just run some gap filler around too.
Step 3
I just used a few 30mm screws to fix the shelves down then used some gap filler to fill over the screw heads.
Step 4
On the other end of the robe I just put one shelf in the same height as the existing shelving and used the same prosses as before but added a baton across the front to support the front edge of the shelf. Then added a hanging rail too.
Step 5
and then again for the storeroom however i doubled up the 42x18 pine across the front edge as there will be a lot more weight on these ones.
KatieC
Retired Team Member
Retired Team Member
Re: Robe & Storeroom Shelving
Hi @Baggs,
Incredible how small projects can have such big impacts! It fits the small projects category for Bunnings' search for Australia's Best D.I.Y. 2023 so I have entered it in for you.
You have done a wonderful job adding more storage to your wardrobe and storeroom. "Grab a big square to check your corners and cut the melamine to suit. This can be a bit tricky to get right but just take your time." - this is a great tip thank you for sharing. You'll find some of our member's projects go into our Top Ideas articles like 10 most popular storage projects, you may find yours in there one day.
Well done!
Katie
JoeAzza
Re: Wardrobe and storeroom shelves
Hi @Baggs you can never have enough storage, this project looks good, well done and good luck for your entry in the DIY July project entry.
Good thinking in making the shelves stronger to take extra weight, this will prevent the shelves from sagging with the extra weight.
