Problem installing mixer tap - sink hole is too large?
slayton
Hi, I'm attempting to install a new mixer tap on our laundry  tub, but the hole in the sink is slightly too big.  The base of the mixer can sit over the hole (just), however the o'ring part falls right through and doesn't form any seal.  Is there any way I can still make this work?
Re: Problem installing mixer tap - sink hole is too large?
Hello @slayton
Welcome to the Bunnings Workshop community. It's fantastic to have you join us, and thank you for sharing your question about installing a mixer tap in your laundry tub.
The holes cut out for the laundry tub plumbing are often 42mm which is a tad larger than the 40mm base of the kitchen mixers. I recommend having a look at the Kinetic 32mm Hole DWV Stainless Steel Flat Cover Plate which has an opening size of 32mm but the outer diameter of the flange itself is 95mm and will have to be cut down with tin snips in order for it to fit properly.
However, there are other flanges and cover plates available at the store and it's just a matter of finding the right size. I propose bringing your kitchen mixer to the store and testing the flanges out to make sure they fit. Unfortunately, there are no made-to-measure flanges for these circumstances. I'll be passing by the store tomorrow and will be having a look as well.
If have any other questions we can help with, please let us know.
Thanks very much for your advice @EricL!  I'll give the cover plates a try.
Keep us updated, @slayton and please reach out if you need further assistance.
Clark make and adapter. By-pass tap hole conversion seal for 41mm holes. I note everhard uses 42mm holes so it will depend on what you have.
https://www.clark.com.au/products/laundry/other-%28category%29/by-pass-tap-hole-conversion-seal
Hello @Gavin3500
Thank you very much for recommending the by-pass tap hole conversion seal. Let me tag @slayton to make them aware of your suggestion.
We're keen to hear more about all your projects and plans around the house and garden. Please feel free to reach out whenever you need assistance or would like to share a project with the community.
Hello @slayton
There was an excellent suggestion made by @Gavin3500 regarding a by-pass tap hole conversion seal. By-Pass Tap Hole Conversion Seal | CLARK. Please note that this product is a special-order item and is not regularly stocked. If you wish to get one, I recommend visiting your local store and speaking to the special orders team and asking them to order one for you.
