How to connect bath tap to washing machine?
ramann
I have the following tap in my bathroom, i want to join a washing machine to it. Which part do i need for this?
My tap opening is slightly oval in shape.
Re: Parts for Tap to washing machine
Hello @ramann
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your washing machine.
I propose removing your spout and replacing it with a Shaw & Mason Chrome Bath Spout With Diverter. In order for your washing machine inlet to fit you will also need to attach a Brasshards 20 x 15mm Brass Threaded Hex Reducing Bush to the diverter outlet. Please make sure to use plumber's tape on all the threaded sections to prevent leaks. When you wish to use your washing machine simply turn the diverter on the spout and water will be re-directed to the washing machine.
ramann
Thank you Eric. Very appreciated
Hello @ramann
I almost forgot, please make sure to use plumber's tape on all threaded fittings.
If you run into any other issues, please let us know.
