Hi, I'm new to this forum but I have had a look around and I am sure I have seen where a Bunnings Team Member did some drawings with what it could look like and I am hoping a Team Member could help me out with the same.
This is the current layout
This is the current layout with a drier mounted to the wall above the washing machine.
We are getting a new drier which cannot be mounted so needs to go next to the washing machine on the floor. so the double door cupboard will need to be replace with the single door broom cupboard.
I also want a bench to go along on top of the machines and a sink to be fitted into the bench with a mixer tap. and overhead wall cupboards.
There is a sliding glass door to outside wich takes up the entire back wall and the bench will need to stop short of that. I am thinking Bamboo laminate bench from bunnings.
I have a plumber booked to change the washing machine taps and other work and an electrician to insall a powerpoint under bench level but I hope to do everything myself, including tilling as the current tilling goes around the built in cupboard and free standing sink. so any tips would be appreciated.
Please excuse my rough drawings, I hope they make sense.
Thahks in advance
Hi @kwakagrl
Welcome to the Bunnings Workshop community. Thank you so much for joining us and sharing your questions about your laundry renovation.
It's great that you've decided to give your laundry a renovation. This is a fantastic opportunity to renew and refresh the look and feel of your laundry. Thank you for posting the measurements of your room and the conditions we should be aware of. I've listed down a few tips for your laundry renovation.
Here is the list of Kaboodle cabinets I used for your laundry.
If you wish to be sure of the position of all the items in your laundry assemble the pantry and base cabinet. Line them up along the wall with the washer and dryer. Don't forget to include the panels, this will now show you exactly where everything will be. You can now be very confident with your placement of the plumbing and electrical services.
Here is a link for ideas and inspiration: Top 10 most popular laundry renovation projects
Here is an excellent guide by one of our members: How to plan a laundry renovation by @Adam_W
This is great! thank you so much.
Hi Eric, Thank you for the drawings, it really helpful to visulise how it will look and what will fit in the space. Also the Acacia project panel is beautiful and very reasonably priced! I had a look at the products you suggested and there are some out of stock. I also am trying to keep cost down so I was looking at substituting with the Flatpax Laundry range and all the doors and hardware are included. Do the Flatpax need end panels? there doesnt seem to be any listed.
Hi @kwakagrl
If you were swapping the Kaboodle cabinets for the Flatpax system the sequence would be:
The Flatpax systems do not require finishing panels as the ends of the cabinets are already finished. You'll need to use the 450mm pantry as the Flatpax does not have an 800mm base cabinet. You will also need to change the wall cabinets to 900mm. It will still fit as you have enough space in your laundry to accommodate these cabinets. Please remember that the Flatpax cabinets are complete and contain all the parts you will need.
