Laundry makover with Practa and Flatpax
sallie24
Having an Impact
Materials
Practa Pantry
Flatpax 600mm base cabinet
Flatpax 300mm base cabinet
Practa white laminate benchtop
Estilo 450mm round sink
White Knight primer and laminate paint in Satin
Duratile white tile 75x300 in white ripple
Davco white 01 grout
Tools
Jigsaw
drill
screw driver
Foam paint rollers
circular saw
Steps
Step 1
Sand, clean, prime with white knight laminate primer. After drying sand again with fine sand block then apply top coat, we left for 24hrs then sanded and painted again.
Step 2
We then painted the skirting and the front of the cabinets using the same steps.
my husband had all the cabinet installed then cut the benchtop to size. We installed a 25mm curtain rod across the bench from the pantry to stud in the wall. We needed to add a 600mm deep laminate panel next to the practa pantry as it is not as deep at the flatpax cabinet for a more cohesive look.
Step 3
We moved onto to tiling the backsplash with the duratile 75x300mm white ripple effect tile with the davco 01 white grout. I decided to not install the drawers on the bottom half of the pantry and instead include space for laundry baskets. We are stoked with how this turned out and can’t wait to use once the plumbing has been completed!
Re: Laundry Makover with Practa and Flatpax
Hi @sallie24,
Nice work with your new laundry.
The colour palette is clean and inviting, and the tiles add an elegant touch of depth.
It looks like a wonderful space. Congratulations on a job well done.
Thank you for sharing.
