Is a SMC basin top drillable?
GeeBee58
Looking at buying the Estilo 1200mm Bathroom Vanity With 1 Tap Hole but want 3 tap holes. Can the SMC basin top be drilled with a hole saw?
Re: Is a SMC basin top drillable
Welcome to the Bunnings Workshop community @GeeBee58. It's sensational to have you join us, and many thanks for your question about drilling into a basin top.
I apologise for the delay in my reply.
It is possible to drill additional holes into an SMC basin top using a hole saw; however, it is not recommended. Drilling into the material can compromise its structural integrity, and there is a risk of cracking or damaging the surface. If you require a vanity with three tap holes, it may be better to consider a model that comes pre-drilled to meet your needs, and I'd recommend you discuss this with a Special Orders team member at your local store. They'll be able to contact Estilo to see if a three-tap hole version is available and show you what else in our range might suit.
