Hi all,
I have a powder room that I want to mordernise without removing tiles or anything. It's 80's wet area so I don't want to open a can of worms by removing any fixtures or drilling any holes. Just looking for some superficial makeover ideas. Everything is in working condition, just needs some love.
Thanks in advance!
Thanks so much @Dave-1 for taking out time and sharing your expertise. This is perfect let me look into it.
Thanks @EricL . Would you know if it is possible to attach VJ panels to the tiles without hampering the tiles or the waterproofing underneath? Can I just glue them on the tile without nailing them?
Hello @tchat
It is possible to attach the EasyVJ panels to a tile wall. The tile surface however must be scuffed, and the majority of the glossy surface removed. This is to allow the adhesive to anchor onto the tiles surface. You can use either an electric sander or a grinder to remove the gloss finish.
Please note that should any of your tiles fail while the EasyVJ panel is attached, it will appear as a bump on the surface finish of the panel.
I suggest using a vacuum cleaner to the walls to remove any unwanted dirt and debris. I then recommend using Selleys 350g Heavy Duty Liquid Nails to stick the panel to the tiled wall. Please keep in mind that attaching the panel to the tiled wall will increase the thickness of the wall. This might have an impact on the skirting and cornice installation in the room.
The EasyVJ panel must be supported with a timber piece while the adhesive is curing. Once the adhesive cures, you can then remove the timber piece.
Thanks Eric! absolutely, we purchased the matching basin and tapware, I will look into tile paint, we're going with a black and white theme so if you have any suggestions with paint, I'm all ears, thank you
Hello @alla
I suggest having a look at the Dulux Renovation Range. It covers tiles, benchtops and laminated surfaces, it's versatile enough to be used for bathroom, kitchen and laundry revamps.
Here is a handy step-by-step guide: How to paint bathroom wall tiles
This is so helpful, thank you! Do we not need to sand the tiles before painting?
Hi @tchat,
Thanks for your question.
With the Dulux Renovations Range, there is no need to sand the tiles, simply give them a good clean with sugar soap to remove any dirt, grease or contaminants and then apply the Dulux Renovation Range Primer before painting with your chosen Renovations Range paint.
Ensure you follow the manufacturer's instructions for use to ensure best results.
