Hi, the cord is broken on my Showers 3 panel sliding door setup, I replaced the cord years ago and I'm sure I got it from Bunnings and it was specific cord for the job, now I need another cord and I can't find it on this site anywhere, I also had a diagram on how to fit the cord, long gone, so is there one available somewhere ?, thank Alex
Hello @alec3
Thanks for sharing your question about your shower door cord. It's possible that it might still be available but under a different name. Would it be possible for you to please post a photo of the cord in order for us to get a better idea of what it looks like. In regards to the installation diagram I did a quick search on the net and can only find the image below. However, I'm not use if it is applicable to your shower doors.
If you need a hand posting the pictures, please let me know.
Eric,
The cord is approx 2.5mm dia,
cord cover
end view
Hello @alec3
Thank you for sharing those photos of your shower cord. I've tried all sorts of combinations trying to find your shower cord, but nothing comes up as an exact same match. I can only suggest having a look at the GRUNT 3.5mm x 5m Starter Cord, and at the GRUNT 3mm x 15m Para Cord. They are slightly bigger than your 2.5mm rope but they are the most robust ones available.
