I have a small unit with a bathroom window that has a 75mm flywire section at the top of the window. It does not seem to have the normal flywire grooves and spline holding the flywire in place.
Any ideas on how to replace the flywire, please?
Kind regards
Mike
Hi @Mike_C,
Let me extend a very warm welcome to the Bunnings Workshop community. We're pleased to have you join us and encourage you to post anytime you need a hand or have a project to share with other members.
Could we please trouble you for a photo of the inside of the window? I understand it might not be a traditional flyscreen, but if you could please try to show how the screen might be held in place our members will be in a better position to suggest next steps. We do have a step-by-step guide by Workshop member @Tara86 covering How to replace a flyscreen, but happy to assist with your specific problem.
Many thanks,
Hello @Mike_C
Thanks for sharing your question about replacing the flywire at the top of your bathroom window. Some assemblies use PVC channels to cover the flywire assembly like in this discussion - How can I fix this odd fly wire set up on toilet window? by @mich1972. However, other modern fittings use aluminium to cover the access to the flywire assembly.
A close-up photo of the flywire frame will definitely help our members assess its assembly. We can then provide recommendations on how to replace it.
Hello
Thanks a lot to those who replied. House is down south so will take photos next time I am down and post them for more advice.
MIke
Hello All
Pictures below. Hopefully you can zoom in and have a look at jhow the flywire is fitted to the window.
(And yes I know the lintels need rust stabilising and repainting - one of the other jobs to do).
Inside
Inside
Inside
Outside - binding seems to be plastic rather than rubber
Outside
Hello @Mike_C
Thanks for posting those extra pictures of your bathroom window. If you have a look at the fifth and final picture you posted, you'll notice that the rubber pieces holding the flywire in place have deteriorated. I believe this is where you need to begin your investigation with its assembly.
I propose looking behind the rubber gasket at the top and see if the flywire is held in place by double sided tape or silicone. This will be your starting point and from there you'll be able to determine how the rest of the flywire is fixed in place.
I strongly suggest having a quick look at this discussion - How can I fix this odd fly wire set up on toilet window? by @mich1972. It's an excellent example of how to put new flywire on your bathroom window.
Please keep us updated with your progress, we look forward to seeing new flywire installed in your window.
