How to replace a sink spout?
Lila
Hi all, I want to replace the existing spout for my bathroom sink with a new one. The problem is the current spout (it's probably the original one) has been painted over with a thick coat/s of paint, with no obvious joins anywhere, and I can see it's going to be very difficult to remove. It there a way for me to do this so I can replace the spout myself?
Re: Replacing a sink spout
Hi @Lila,
As @Dave-1 has mentioned, to gain access to that nut, you'll probably have to disconnect the entire breech, which is the copper pipe between the handles and spout. Hopefully, that will give you enough access to get a basin wrench in there.
Please remember that this is considered plumbing work, requiring a licensed plumber to perform it.
Lila
@Dave-1 thank you for your reply.  Looks like it's a job that's a bit (actually, a lot) out of my league, but at least I know what needs to be done now.  Again, thank you.
Lila
Hi @MitchellMc, thank you for taking a look and for your advice.  Yes, it looks like it's something I may need to leave to a professional.  But thank you for steering my in the right direction.
I've just had an afterthought ... when it comes to changing the taps, is it a simple matter of undoing them at the top, or do I need to approach that job too, underneath, based on the picture of my fittings?
I've already bought my new tap fittings, from Bunnings of course, and was going to have a try at replacing them myself, but if you think I should leave that job too to a professional, please let me know.  Thank you!
Hello @Lila
If the tap set you've purchased includes the brass body and not just the handle and flange set, then I propose allowing the trade professional to install the rest of your tapware. In this manner the entire tap set is covered under the installers warranty. However, I suggest observing the installation so that you can see how it's done and next time you need to update any of your tapware you'll be familiar with the steps.
Lila
Hi @EricL I purchased a boxed (matching) Shaw and Mason white and chrome taps and spout set.  I haven't opened the box yet but I'm guessing that includes the brass body.  Would that be right?
If it does, I'll just get a licensed plumber to install it, as you suggest, since he has to come for the spout anyway.
Thanks for the tip.
Regards, Lila
Hi @Lila,
It would be best to have the plumber install it all at the same time.
Lila
@MitchellMc .. gotcha. Thank you!
