How to replace a light?
I would like to know how to replace the lamp like attached photo. I cannot see any screw around the light. Except 2 holes both ends of the light.
Re: Replace a light
You find our range of LED batten lights on our website. I suspect you'll be interested in the 60cm long versions as they'll be the closest in length to your current fixture.
Please let us know if you have more questions or require further assistance.
Re: Replace a light
Hi @quynhpham55, @MitchellMc ,
Given that this is a filament (incandescent) type lamp/fitting, I don't like the chances of you being able to get replacement lamps, going forward.
Also, regarding this being installed in a bathroom, I would recommend something LED with an IP rating, there are fittings like this that are designed for this very situation and it will more than likely be a lot brighter than the existing lamp.
It would also be a lot safer if the circuit that supplies this fitting has an RCD on it, because of it being able to be reached while standing on the floor.
- « Previous
- 1
- 2
- Next »
Subject | Author | Posted | |
May 2023 | |||
December 2022 | |||
July 2021 | |||
September | |||
February 2023 |
