Hi all,
We recently moved into a house and noticed an issue with the window frame next to the shower. The bottom of the frame has some broken pieces, which we suspect is due to previous improper sealing around the shower. After a closer look, we didn’t find any visible water damage outside the shower, and we also tested the surrounding wood [Identified during building inspection as a minor issue], which seems solid with no signs of rot.
I cleared out the broken pieces of the frame, and upon inspection, there doesn’t appear to be any internal rot either. Based on my research here, I’ve seen some posts suggesting using Earl's 250ml Wood Hardener and Turbo 175ml Builders Bog Flexipack to repair the damage.
Before I go down that path, I wanted to check if anyone has alternative recommendations or steps I should consider. Is this the right approach, or should I be looking at a different method to fix this damage properly? Any tips on preventing similar issues in the future ( re-silicon the shower)?proximity to the shower
close-up
Thanks in advance for your help!
Hello @SouthFieldSnoop
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about fixing the damage to your window frame.
Your research has paid off. I was going to recommend those two exact products to fix the damage on your window frame. The only time I would suggest cutting and replacing the wood is when more than 50 percent of the timber has rotted away. In this instance the damage is still manageable, and builders bog can still be applied.
My best advice is to use Crommelin 1L Flat Aquablock Waterproof Primer Undercoat - 1L to protect that damaged section of your frame and applying silicone on the edges of the frame.
Thanks, Eric – That was really helpful!
Just a couple more details for clarity:
Appreciate any further advice!
If you are worried about not having enough bog for the outside surface, I suggest filling the cavity part way with Parfix 340g Expanding Foam Filler. Just keep in mind not to over fill otherwise there will be no space for the bog. In regards to the paint size, I believe 1 litre is the smallest can available.
