How to remove this toilet paper roll holder?
sisimon510
I've been trying to do some small scales renovation for my new home.
I plan to remove this toilet paper roll holder and replace it with a new one. Initially I thought there will be a tiny screw for me to remove so that I can take the holder down. However, it seems that there is none! I tried to pull it out a little bit - only finding 2 whitish ?plastic toggle attaching the holder to the drywall.
Any thoughts?
Re: How to remove this toilet paper roll holder?
Hi @sisimon510,
You're correct that a small grubscrew would typically lock the holder onto the wall bracket. If there is no screw, then it might be some type of 1/4-turn locking mechanism. It appears like the bracket might be held onto the wall with a nylon Wallmate-style fixing. Have you tried unscrewing the whole holder anti-clockwise? Pulling slightly on the holder whilst unscrewing might create enough friction to unscrew the fixing from the wall.
Thanks Mitchell.
I tried to unscrew it anti-clockwise today, but it was so tight that eventually the whole thing comes off...
If I plan to buy a new toilet roll holder, and just in case these 2 holes can still be used, what sorts of hallow wall anchor should I be using?
Or should I just fill the holes with joint compound, and drill new holes for the new toilet roller holder?
Thanks!
Hi @sisimon510
I'm glad you managed to get the toilet roll holder off. Did you get to find out if it was a twist off feature or was there something holding the toilet roll in place?
In regards to the new toilet roll holder, I recommend filling in the holes and finding a new spot for the new toilet roll holder. I suggest using UNi-PRO 500g Multi Purpose Interior Filler to fill the holes.
Please make sure to tear off a small piece of the paint near the holes so that you can show it to the paint specialist when you have your paint colour matched.
Ronb1949
Is it a good idea to use toggle-bolts to attach the new toilet-roll holder using the existing holes?
It would be better to use spring toggles if you attempted to use the existing holes @Ronb1949. They'll grip the back of the plaster better and prevent the fixture from being pulled off the wall.
