How to remove spa bath?
robpa
what is the best to use cutting around the edges of fibreglass spa bath
a circular saw or angle grinder or any other tool?
regards Robpa
Dave-1
Community Megastar
Re: how to remove spa bath
Good Evening @robpa
That is a question I have thought of for awhile. I have an external spa that I intend to heat via a dutch spa type deal. If it dosnt work then I may chop it up as well, hence how to cut it. I have thought a grinder with a fine cutting blade but as I was thinking of your question maybe a saber saw would work as well with less fumes? It would come down to how tidy a cut you may want. How about a jigsaw if you want a certain cut? Drill a hole fist then jigsaw it?
Welcome to the Bunnings Workshop community @robpa. It's sensational to have you join us, and many thanks for your question about cutting fibreglass.
I'd agree with @Dave-1 that either a reciprocating saw, jigsaw, or multi function tool would be the best choices. The effectiveness of cutting through the fibreglass will be in that order, too, from most efficient to least.
Remember your PPE, including safety goggles, gloves, enclosed footwear and disposable overalls.
I'm using a pretty low end reciprocating saw to remove an old fiberglass spa shell. It's pretty hard going. I was using generic all round blades, burned out one cordless motor then upgraded to a diamond blade. Was slower going. Neater but slow. So I switched back to a spare wood blade which ripped through in faster time. Have had to stop as there's smoke coming from the motor. Still, slowly getting there. Started a month ago so we could access significant drain at top of pic. Spa was obviously installed by shifty plumbing. Expect to be done by Xmas.
Hello @Scalesy
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about removing your spa.
Your making good progress, all I can suggest is to give your saw a break when you feel that it is starting to overheat. I also recommend cutting the spa right in half rather than cutting it into smaller pieces. By cutting it in half you should be able to remove it in one go rather than in small pieces which is a lot of work for your saw.
