What is best way to remove rust on door frame next to shower
Welcome to the Bunnings Workshop community @suejems. It's brilliant to have you join us, and many thanks for your question about removing rust from a door frame.
It would be very helpful for our members when offering advice if they could see what you're working with. Please let me know if you need a hand uploading images.
Typically, rust forms on steel when exposed to moisture, so it sounds like a painted coating might have deteriorated. The typical method of rust removal is through abrasion and sanding. Once the rust has been sanded back, it can be treated with a rust converter. After the rust converter has had time to work, the area can be primed and painted to exclude moisture from the area and improve its appearance.
